OK time for an update -
We haven't been moving all that fast - No work was done last weekend, but we got a good day in yesterday.
(no photo's though - not much to photograph yet)
Storage: Storage in the SWB ute is a bit of a curse, as access to behind the front seats isn't good and because the ute back overhangs the bulkhead, items stored up against the bulkhead are difficult to get to when the car is packed. We have also made things worse because of the shock mounts tough the floor in the back.
The resolution there was to run a rifle case sized spacecase behind the front seats (cab side of the bulkhead) This will be long enough to fit axles etc and keeps the weight between the wheels. It will be fiddly to get out but most of the stuff that's in it won't be coming out very often.
For frequently used tools, two 50cal ammo boxes will sit on the tub beside the storage rack. These are 12"long X 6" wide X 7.25" tall and much cheaper than commercial toolboxes (they also seal better and are stronger) They will be very easy and quick to get to. they won't overhang the sides at all and will be strapped down so they can be pulled off easily to take to where theyre needed.
Seats : Michael has chosen not to put the busted, torn, smelly, brown vinyl seats back in
It look slike he is keen to go with sparco sprints, the same as I have been running for years and Mitch has for Doof. The drivers one can be fixed or on runners and for the passenger side it looks like the mount will be a 1.0 passenger mount which pivots the whole seat forward with a parallelogram base. This moves the seat further out of the way than a sliding base and works with fixed back seats (like the planned Sparcos.)
Front Clip - Michael has decided to go with a 1.0 front clip, as it will suit the look of the finished car better. I'm also pushing for a 1.0 bonnet too - I think they look heaps better.
Colour- I think Michael has settled on CAT yellow.
Engine: Nothing to report ATM.
Gearbox: We had a flexplate supplied with the trimatic gearbox, but when we tried to bolt that to the motor, the flexplate fouled the oil blanking plate on the back of the block. I pulled out an old flexplate I had when I bought my trimatic in about 1997, and it cleared. Turned out they're 0.57mm different in mounting face to starter drive ring. Wierd. Anyway, that sorted that out.
The tailshaft housing plate has been made. It's 6mm steel, chosen over alloy because if neccessary, we can weld mounts on to it easily or tap it for bolts. A bearing block and seal needs to be sorted, which is a little bit complicated because the sierra slip yoke is 32mm diameter, which is 0.2mm bigger than 1.25", the next common metric size being 35mm. I will do some research into this this week.
Jackshaft/Transfer: because about 40mm will be coming out of the jackshaft, we'll be lifting the transfer case to get the best possible angle on the jackshaft. This will also lift the shifter and disconnect lever and flatten out the underside of the car.
Wheelbase - we will be pulling the rear axle back 1" or so. This is only really because the rear drivshaft is a little bit long ATM with the rear disconnect. We'll be doing this just by redrilling the spring pads.
Rear axle - at this stage, I think we will be going with a stock WT housing set up as a full floater. Michael's car doesn't need the extra width and as he needs to run 3.7-3.9 diffs to work with his three speed (non overdrive) automatic. That rules out a vitara centre, and the ring and pinion strength with the tall ratios shouldn't be an issue.
Unresolved issues - Coolant pipe locations, power steering pump (looking like EB falcon) and method of vitara steering box mounting- Michaels extension etc was built around the stock steering box, so there's some work to do there.
That's all for now - we're getting the tub off next time we're working on it so we shoudl have some photo's of the engine/gearbox mocked into place.
