T case lift
T case lift
Sierra
T-Case lift
Do people know where I can source some polyurethane blocks suitable for this.
I presume Steve that you used some sort of sleeve nut to fit your blocks?
Re: T case lift
I use a polyurethane isolation mount from Purple Pig in Bayswater that is about 35mm taller than a stock rubber mount.
I believe they are a custom item moulded for my dad (who uses them on industrial equipment), but I bet they have a part that's almost identical or might even be better.
On the face of it, these shouldn't be strong enough, but they seem to be very durable- they are now in Greg's car, Michaels car (which was murdering rubber mounts) and my car.
Otherwise, I bet Purple pig will have some generic urethane bushes that can be adapted similar to those sold by spidertrax for their HD transfer case mount kit.
