Wow! Finally got a decent turning circle again with fingertip control. Power steering is in and now looking forward to getting out to have a play.
Questsion for those that have done this conversion, do you need a steering stabiliser as the sierra one doesnt bolt on anymore.
Regards,
Bill
power steering finally on
Re: power steering finally on
Well done Bill :jealousy emoticon:
Shouldn't need one- they only mask problems, they don't actually "fix" anything.
Looking forward to dropping the fronts down finally to 6-8psi and run a front locker. Should be less fatiguing and will hopefully stop me whingeing! I doubt it!
Mines fine without the stabilizer, was intending to put it on, but it is still in the garage drawers .. Never had death wobbles since fitting ps.
If you need to build your upper arm strength, I will have some crutches available in a few weeks
