G13a Build questions
Ookie the zuke
Post by Ookie the zuke »
Hi guys. I just has a few questions about parts interchangeability between a g13a and g13ba. I was just wanting to make sure I am correct.
I currently have a g13a in my zuke with a cracked block between the coolant jacket and cylinder.
from what I understand I can use either a G13a or G13ba block as they have all the same dimensions. If I use the g13ba crank I will get a slightly reduced displacement, however I can still use the g13a crank in the g13ba block with no interference.
additionally I believe that the pistons, rings, head gasket and bearings are interchangeable between a g13a and g13ba.
am i correct in this thinking?
Cheers Callum
