Anyone looked into building a rally style cab like they put on the gypsies in India? Granted the one in the video would look a little odd on my SWB but I still like the concept.
https://youtu.be/LLk1u6q8uR0
Rally cab
Re: Rally cab
they are around in australia just not exactly like that they are a bit less fast back or couoe style if you know what I mean, more of a steep angle
Re: Rally cab
Yeah, not too keen on the cost of those. Surely this is a good introductory sheet metal fab project. I'm sure I'd prefer it to be removable though. To sit comfortably in my cab my head rest sticks past the b pillar by a good way so a neat stock looking cab close off is not suitable.jonfromhamilton wrote: ↑Sat 04 May, 2019 9:01 am they are around in australia just not exactly like that they are a bit less fast back or couoe style if you know what I mean, more of a steep angle
Re: Rally cab
a diy sheet metal rally cab would be a glorious addition to your chariot
Re: Rally cab
Love the fast back cabs.
I made my space cab out of ply and alloy, cos my welding sux.
Re: Rally cab
Love that. I've already made a ply cutout to shut off the tub section. Been watching Trev's blog on YouTube and he has some new vids about forming sheet metal over wooden shapes. Must get my hand on some steel sheets and get shaping, bending, riveting, etc etc. Considering using front window glass but might need too big.
Re: Rally cab
sheets of polycarbonate from bunnings may make good windows. Can cut pretty easily. Come in tinted as well.
Re: Rally cab
Could probably use polycarbonate sheet for entire rear wall.christover1 wrote: ↑Mon 06 May, 2019 6:56 pm sheets of polycarbonate from bunnings may make good windows. Can cut pretty easily. Come in tinted as well.
May need side windows if going any longer than that.
Re: Rally cab
Polycarbonate is terrible with UV. It will get brittle.
My 2c- buy and modify a maruti cab back. Recreating the contours/window rebate etc will be a nightmare.
Re: Rally cab
Polycarbonate is UV stable according to many sellers, and also comes with extra uv coatings as an option.gwagensteve wrote: ↑Mon 06 May, 2019 8:52 pm Polycarbonate is terrible with UV. It will get brittle.
https://www.jrtindustries.com.au/cut-en ... carbonate/
But I agree, modifying an existing cab is much easier.
I started with a broken hard top cut down, filled flatter areas with ply,
and reused the window from the hard top.
