constant on headlight plug?
ok so im tryimg to understand the witch craft happening in my loom. im getting constant from all female points on the headlight plug but if i plug it on the back of the headlight the heqdlight doesnt turn on until i turn the lights on at the steering column.anyone?
also none of my blinkers are working :/
it seems as though there is a positive and negative out of the factory indicators. the red blue. its mot earth out of the indicator idk whqt it is
Re: constant on headlight plug?
Headlights and another of other circuits in suzukis are negatively switched.
Power goes from the battery to the fuse, then to the headlights in parallel then to the switch then ground.
Because the headlights are wired together and maybe some other lights, even if you unplug one of them, both sides of the connector will have + power at all times, you would need to disconnect everything in the circuit to stop picking up power on the ground side of the connector.
yah i got it working
