Front Left Hand Indicator Sender
rivm2001
Post by rivm2001 »
Hi,
Hoping someone can help me identify the correct name for what I think is the front left hand side indicator sender for my 1993 Suzuki Vitara JLX.
Also hoping that someone could please advise where I can purchase a new one, as this one appears to be faulty.
Re: Front Left Hand Indicator Sender
Not really sure what you mean by "sender" - what is the problem exactly?
rivm2001
Post by rivm2001 »
The blinker on the left hand side is not working. I can send you a photo if you like?
If it's just the one light, it probably just requires the bulb changed. Pull the old bulb and grab a replacement from a decent servo or an autobarn/repco/bursons
rivm2001
Post by rivm2001 »
No I tried that, it doesn't work. It's that actual sender unit that holds the globe that's not working
That's still not very clear.
is it the bulb fitting that is in the lens or is there no power going down the wire, have you stuck a multimeter on it?
there is only one "sender" the flasher unit, that runs BEFORE the switches for the indicators/hazzards.
Christover is parting out his car he will have a spare indicator.
rivm2001
Post by rivm2001 »
I can send you a photo if you like of what is not working. We tested it with the multi meter and have narrowed down the problem. I can't seem to attach a photo here
you need to post the photo on another service like photobucket or google photos and embed in the forum using
Code: Select all
[img][/img]
tags 8-)
https://www.phpbb.com/community/app.php ... 2ddb822e7e
Richardnclark
Post by Richardnclark »
try search on ebay or go to Suziworld in Diamond Ck.
rivm2001
Post by rivm2001 »
Hi All,
Here is the link to the photo:
https://1drv.ms/i/s!Av7lsEM171Drnsc6J5pJZ0UWXeWX-g
