Work on Ben's Zook Day
Quinny
Post by Quinny »
Hi All,
Looking at planning a working weekend on my zook at Lukes place, thinking about camping over night with a BBQ/Roast.
Still working out dates, Luke what weekends are you free?
Cheers,
Ben
Re: Work on Ben's Zook Day
I'm keen, depending on date
Hi. What's the plan? Need to understand if I can be of any assistance.
Quinny
Post by Quinny »
Taking it back to SPUA, Changing the Diffs to 5.125 Ratio, may pull the auto to see if can find a strange sound it making.
Quinny wrote:Taking it back to SPUA, Changing the Diffs to 5.125 Ratio, may pull the auto to see if can find a strange sound it making.
Mine made a strange sound after fitting a new skinny starter motor. The flex plate was scraping under some loads. Found out later some shimming is needed with many starters, learn summit every day
Quinny
Post by Quinny »
sounds very simular to my issue chris, i might have a closer look at the starter motor clearance.
Mine makes a awful grinding sound coming off the accelerator at 3k rpm or above
Cutting MASSES OF STEEL out of the guards...
porter.8.luke
Post by porter.8.luke »
I will post date just have to confirm with Liz.
Luke
porter.8.luke
12/13th of November.
Luke
porter.8.luke
Bills block is confirmed for the 10/11th of December.
Luke
