Just replaced my old engine mounts with vl commodore engine mounts. Thanks Steve125. I never would have known about that upgrade if I hadn't met you blokes. Wow what a difference. My old ones were stuffed.
Regards, Wayne.
Hi Kiwi. The locating pins are in a different place. I had to drill another hole.( 3/16 half depth hole) Apart from that, the left side bolted on.
I had to slightly elongate 2 mounting holes on the right side. Only because everything was still attached to the motor and it was difficult to position.
So ,yes the holes all line up.
Regards, Wayne.
