Hi Guys,
My sierra leaks grease out from the CVs, after a days driving just around town usually the inside wall of the front tiers are splattered with grease.
Very similar to what is described in this document: http://homepages.maxnet.co.nz/martincat ... 0Joint.pdf
Should I be concerned? Is it something that needs fixing asap or can I just squirt some more grease in somewhere until i do get around to fixing it?
Leaky CVs
- Brad.Jones
Leaky CVs
Re: Leaky CVs
that seal is easy to fix brad. it's litterally a wheel off, then lean in a remove 8 bolts, new seal goes in, put 8 bolts back, put wheel back on. easy.
if you are concerned that you have lost too much grease - then you need to do a bit more work (remove the spindle) to put more grease back in there.
i think the seals come in a 'sierra knuckle rebuild' seal pack.
Re: Leaky CVs
Brad, it's likely that the inner axle seal (the last image on the link you posted) has failed, and diff oil is weeping into the CV housing, washing out the grease.
That's why it's falling out of the knuckle seals. If it wasn't being diluted by the gear oil, it would stay where it was.
However, the method for getting in there in link you posted is the most complex way possible.
If your wheel bearings are in good condition, the procedure is as follows:
Remove the wheel
Remove the brake calliper bolts& calliper. There is no need to remove the brake hose so bleeding isn't required.
Remove the brake rotor
Remove the 6 6mm bolts on the free wheeling hub.
Remove the cir clip.
Now you can get to the spindle bolts. Remove them (you can't use a ratchet or ratchet spanner, you will need a 14mm ring spanner
Now the whole hub will come off without disturbing the bearings.
Pull the axle out
clean out the CV housing
pull the seal
Replace the seal
Put it all back together.
It won't take more than an hour per side.
I don't think its necessary to change the knuckle seals - if I'm right, they will be serviceable, it's the dilution of the grease that's the problem
Remove the wheel
Pull the axle out
pull the seal
Replace the seal
- Brad.Jones
Re: Leaky CVs
You guys are such a wealth of knowledge. I appreciate it a lot.
So you recon I can get away with just replacing the one seal...
I have only managed to find knuckle rebuild kits which are about 100 bucks per side which seams crazy if all I need is the one little seal.
Would repo / super cheap have what I need?
Re: Leaky CVs
Maybe.
Check that there's no play in the wheel bearings or kingpins before you start. If there is, then you need to go for the full kit.
Re: Leaky CVs
Great information. I also have a leaky seal in my front axle. Thanks.
- bunnyblaster
Re: Leaky CVs
Good-day Brad,
Did you manage to source the seal only? I have the same problem, but don't need king pins or bearings.
Chris
Chris
Re: Leaky CVs
I sell seals.
give me some sizes and I can tell you if I have anything.
- Brad.Jones
Re: Leaky CVs
No I ended up getting brand new CVs and a full knuckle rebuild kit for both sides.bunnyblaster wrote:Good-day Brad,
Chris
More than I needed but I have got a few spares now.
- bunnyblaster
Re: Leaky CVs
Steve, how much King pin play is too much?
I have no wheel bearing movement, but there is movement in the king pins.
The wheel bearings were tightened but not replaced in 2007.
I am trying to work out if it is worth doing the complete reco or just change the axle seals.
Chris
Chris
