Not only does it read temp better, and the engine runs better,
but air con now works again, and its extra cooling fan no longer stays on?
Must have a trigger for air con in cooling circuitry.?
I discovered problem during a coolant replacement,
It had an idle high/sporadic problem after the change,
that was fixed by bleeding air out of cooling system.
You learn something new everyday.
My first lesson in EFI maybe
