Roll cage steel
Jonno
Re: Roll cage steel
Post by Jonno »
Greg wrote:Jonno - has it arrived yet? this is seriously holding up my build now!
Yes it has! It has now been unloaded into Gregs garage. Everyone please contact Greg to arrange pick up.
I will be contacting Jim to see when its convenient to pick up the bender
Re: Roll cage steel
I would like to bend mine up along with someone else and even better if we are going to have a few people are going to do their bending all at the same time like a tech day I'm into that
Re: Roll cage steel
Jonno wrote:Yes it has! It has now been unloaded into Gregs garage. Everyone please contact Greg to arrange pick up.
what tube? :roll:
Re: Roll cage steel
I'm keen on a shed day type thing too
Re: Roll cage steel
OK so just confirming our low range order.
2x Chromoly Interlocking Tube Clamp, for 1.75" O.D. .120" Wall Tubing (180112-KIT)
Jonfromhamilton
1x Electric Brake Line Lock Kit
1x Chromoly Interlocking Tube Clamp, for 1.75" O.D. .120" Wall Tubing (180112-KIT)
Jonno
1x 3/4" Suzuki Driveline Spacer SDT-DS-.75
Jono165
2x Chromoly Interlocking Tube Clamp, for 1-1/4" O.D. .095" Wall Tubing (180095-KIT)
1x Suzuki Samurai/Sidekick/Tracker Differential Master Rebuild Install Kit
1x Toyota Solid Pinion Spacer
Does anyone else have anything they want? this is the final chance I'll be placing the order this afternoon.
Re: Roll cage steel
let me know how much I owe you (including freight) Jonno so i can transfer it to you before I spend it :)
Re: Roll cage steel
Hey folks,
Since we are all spending up big on tube, I propose we all spend $7.00 more and get a first aid sticker on each car to indicate where our kits are stored.
Thoughts?
I can do a bulk buy and bring them to the start.
Thanks,
Re: Roll cage steel
Oops, not 7, only $6.00. Bargain!
https://www.rsea.com.au/products/685608
Re: Roll cage steel
No problem here from me. Good idea.
steve125
Re: Roll cage steel
Post by steve125 »
Just remember to put the sticker on upside down so you can find the first aid kit when the car is sitting on its roll bar :) .
