Soft Shackles - Group Buy
Re: Soft Shackles - Group Buy
Yeah 2 pairs for me please.
joshyboy26v2.0 wrote: Fri 23 Aug, 2019 7:35 pm Better make that 4 pairs
Sounds like on-selling to me! We better put a limit of 100 pairs per customer just in case :mrgreen:
joshyboy26v2.0
Post by joshyboy26v2.0 »
You should see my mark up!!
2 pairs please
Hi Jono do you know if the rating of 15T is a the breaking strain of these shackles? I would be interetsed in a couple at 20T or 25T as well if there is an option in sizes and if 15T is the breaking strain. For use with the Disco and the 12T snatch strap.
Hi Mike. 15T is the breaking strain and is the larger size available. Specification are as per below. I would think these would be fine for your suzuki or the disco.
Specification:
2 X AOB Soft Shackle(approx 12mm)
To replace heavy, hard to open traditional D shackles.
Brightly coloured RED so it can be seen in low light or in mud and it floats if you happen to need it in water.
AUSTRALIAN CERTIFIED breaking strength of 15,000kg so will be stronger than any D Shackle you have in your kit.
Light weight and won’t rattle.
Much safer than traditional metal D Shackles.
Many are using these in place of winch hooks also as they're much safer.
Keep a couple in your kit for next time you’re pulling your mates out of trouble.
approx 61cm (24") long when open.
approx 19.5cm (8") as a closed shackle.
Caution: Anything larger than 12mm will most likely NOT FIT your recovery points
OK Jono that sounds fine.
Quinny
Post by Quinny »
I'll get 1 pair
Do I bring cash to coming meeting? Or bank transfer to you or the club? Or still waiting on finalizing?
Jonno
Post by Jonno »
1 pair for me pls mate
