A) I've done some reading about anti-lag used to provide no load boost for launching drag cars. This is how it works:
When anti lag is enabled, without having your foot on the accelerator at all, the following things happen - Ignition timing is massively retarded, Idle air control is opened up to let air into the motor, and the car is richened up. The result is lots of unburnt fuel in the exhaust, which burns in the manifold and spools the turbo. apparently, effectively full boost is available when the car is at idle. Motec, for one, can run this function.
B)Stock EFI cars drop fuel out of the car to rev limit them. With fuel pulled, revs and boost fall the engine simply runs out of power and cycles. BwaaaaBwaaaaBwaaaa style.
C) Most of the fastest Japanese drag cars eliminate the fuel cut rev limiter and replace it with an ignition cut rev limiter. I thought this was to to raise the stock limiter. They don't use nitrous to get boost into the cars off the line (very common here in Australia) they just run them up to the limiter all banging and farting and spitting flames, and launch. More on that in a minute.
D) The other day, for some reason, fuel pressure on my aftermarket fuel pressure regulator spiked up to nearly twice correct pressure - about 60PSI. The car ran like poo, but made lots of boost with no load (10PSI on the gauge while free revving with it popping and banging)
E) Reading about the Jaycar shift light kit I have, it drives an ignition cut rev limiter, and warns that if the car is driven on the limiter, very high exhaust temperatures will result (due to the excess fuel not being ignited until it gets into the manifold.
drawing this stuff together, I've had a bit of an idea.
Let's say I fit the Jaycar rev limiter, but set it at about the engines boost threshold, so I free rev the engine to, lets say, 3000rpm. At this point, the limiter starts pulling sparks out of the engine. The throttle is fully open, so there's lots of air in the motor, and boost was coming on when the limiter kicked in. However, There's lots of fuel not getting burnt, and this should be going through to the exhaust. This should be burning in the exhaust and spooling the turbo, but the revs can't rise- The car is being fuelled for 3000rpm, it's making full boost (or thereabouts.)
If you haven't read between the lines already, the idea is that if I can , say, throw an arming switch and then activate the system (activated by having the clutch pressed) I might be able to get full boost at sensible revs, and therefore launch the car with maximum torque at the wheels, instantly. It's not going to be all that useful, but It might really improve performance in mud and on greasy hills. With a working handbrake, it might make, say, 3rd low assaults on nasty wet hills a piece of cake - handbrake on, switch on, clutch in, foot to the floor, 3000rpm, 10PSI boost, clutch out - bang! - instant, full torque at the wheels, in a tall gear, so lots of wheelspeed.
It might also break everything, and melt the turbo, or not work at all
I do plan running an EGT gauge to prevent melting the turbo/exhaust, and know it won't be able to be run often/for long, but it might be useful in hard terrain.
