I sourced a Vitara viscous fan from pick-a-part, and modified it fit my 660. All common sierra/vitara motors have the same fan bolt pattern AFAIK and also seem to share the same spigot size.
However, models with viscous fans have long water pumps with studs fitted to them, whereas models with fixed fans have spacers and bolts. This presented a problem for me as I couldn't install the bolts and spacer as the hub of the viscous fan was in the way. I noted that alignment of the fan is done by the spigot, and that the bolts only provide tension to keep the whole thing assembled, so I figured I could slot the bolt holes in the fan hub for assembly with no ill effects.
Here's some pics.
Here's a 4 blade 1.0 fan, a vitara fan, and a 5 blade fan ( in this case from a factory 660, but I think it's the same as a 1.3 fan)
Here's the 660 fan over the Vit fan. Should pull a bit more air methinks.
Here's the install. I used a 1.3 shroud, not the much deeper 660 shroud. Also, the fan wouldn't clear the bottom of the 1.3 shroud due to the diameter. I cut the bottom of the shroud out and added a strip of shroud from a vitara. It's attached with 6mm screws and nylock nuts.
I haven't had it on the road yet, but it's doing all the normal viscous fan stuff, like freewheeling under revs on a cool motor etc. Clearance between the fan and shroud is pretty tight - maybe 5-10mm, and it remains to be seen if I will have to enlarge the shroud more to allow for engine movement under load, but the engine seems to sit pretty still so I might be OK.
I think with this setup, I should both gain HP and have better cooling when required - along with a huge reduction in cabin noise.
I'm pretty happy. This mod should work on 1.3 Sierras too with the shorter fan spacer of the 1.3 instead of the loooong spacer of the 660.
