Vitara H20a swap engine H25a
Cesarvit
Post by Cesarvit »
hello everyone, I have a vitara v6 h20a, I have a problem with the engine that could be the engine head gasket because I have water coming out of the exhaust and white smoke, in this case I don't know what to do or what do you recommend if I change the engine to h25a or try to fix the problem h20a :roll:
What workshops can you recommend in the city of Melbourne?
Thank you very much for your answers Really appreciate
Jonno
Re: Vitara H20a swap engine H25a
Post by Jonno »
Hi Cesarvit
Have you considered removing the head and doing the job yourself? There is a head shop in Carnegie that can machine the head for around $100 cash and a gasket kit is pretty easy to source. Might be cheaper/easier to repair it than trying to find another engine?
Also do you know what caused it? Did it get hot
Not sure about the H25 swap but I am sure some of the others here may know. Would be a good upgrade if its not too difficult to do. I wonder if the ECU needs swapping to match the motor as well?
Let us know where you are located, might be a few members around who can give you a hand if needed?
