Starter motor stuck
andrew.donegan
Starter motor stuck
Post by andrew.donegan »
Hi everyone
Starter motor is intermittent.
Solenoid is working. Seems as the the starter has an issue.
I’ve tried to remove but top bolt is tooo tight and can only fit an open ended spanner on it. I’m worried I will strip it.
Any hints on removing? 91 model 1.3lt
I’ll try and get starter rebuilt unless there’s a better solution?
Cohengoo
Re: Starter motor stuck
Post by Cohengoo »
A brand new starter motor is around $100 to your door from eBay or your favourite online auto parts store.
Jonno
Post by Jonno »
Sounds like you need to try the "Clicky starter fix"
https://auszookers.com/forum/viewtopic.php?f=5&t=14695
(Please do a neater job than this dude)
I thought if the bolt was too tight maybe the bell housing might be linked. Check of any of the other connecting bolts are loose if there an uneven loading across the bell housing maybe it's holding onto the starter motor
andrew.donegan
Hi Jon I reckon you’re onto something there
I managed to loosen the top bolt on the starter and it fixed it.
However after doing it back up it’s stuck again.
I’ll have a look at the bell housing next week
Some after market starters need a spacer to prevent that. Fixed one of mine that way.
