10mm Key Steel
10mm Key Steel
I have been trying to think of ways to use 10mm key steel to get oil in my diff. Its making my brain hurt. :lol:
Jonfromhamilton (Hi Kiwi) :) wrote. "I even have some 10mm key steel for getting oil in my diffs"
Can someone please explain this to me. :?
Re: 10mm Key Steel
push/tap/hammer the key steel into the 10mm square drive fill plug. Then you can put a spanner/shifter/(even a socket if you have an appropriately sized 12 point socket) and undo it - Key steel is just chosen because it's stronger and has sharper corners than 10mm square bar.
Re: 10mm Key Steel
Thanks Steve.
Something learned. :)
Re: 10mm Key Steel
and ur 3/8 drive ratchet will eventually fuck the plug
Re: 10mm Key Steel
That one had me thinking also
Re: 10mm Key Steel
I used fill plugs from something else, can't remember from what, but had a spanner end instead of the square hole. I remember having some hex head type as well, which were better than square
