Anyone know if a collapsable steering shaft really neccesary for the BenT install kit?
Or can you substitute with a grinder and welder??
power steering install
Re: power steering install
I chose to use a collapsible shaft as my welding is not anywhere near good enough to weld major steering components.
I would guess welding is not permitted legally/engineering wise. (just a guess, don't know)
Hi Kiwi.
I fitted power steering to my sierra recently. I shortened my steering shaft and welded it back together with a piece of tube over the top of the join. The tube holds it true while you weld it. As well as giving a strong join. I also used the Ben T kit.
Regards Wayne.
Hi Kiwi.
Regards Wayne.
I would use a collapsible shaft.
No, cutting and welding steering components isn't legal, and most engineers will not entertain the idea at all.
Did you stick with the collapsible steering shaft?
Lot of garage work needs to be done this weekend. Anyone here has experience installing a ReadyLift.
I will hunt one down once i have the time do do the conversion. Nothing is happening in a hurry at the moment
+1 for a collapsible steering shaft
I see... good luck then.
