zook gearing
tomzook
zook gearing
Post by tomzook »
Hey all,
i have a 90mdl SWB sierra with newly installed calmini 5"shackle reverse and 31" tyres. The gearing is now horrible plus losing use of fifth gear (just dies when put into fifth). i was wondering whether this is a common problem for the zook's? Also i have been doing research on putting some gears into the diffs (before going transfer gears) to try and revert to near standard gear ratio's. I was hoping for some insight on what gears to get??? Please Help.......
muppet_man67
Re: zook gearing
Post by muppet_man67 »
easiest and cheapest way to fix your problem is to get some transfer gears from Low range off road in the U.S. they also have a high range reduction so will fix your on road gearing. diff gearing usually costs about the same money and doesnt give as effective results off road. You wont need both for the size tire you are running.
tomzook
Re: zook gearing
Post by tomzook »
Thanks for the info. Now i was not aware that reduction gears for the transfer would improve the road travelling gearing hence the reason why i wanted diff gears. Do they reduce even when in 2 wheel drive? Sorry if these questions sound a bit dumb i am somewhat of a noob.
Re: zook gearing
Most after market gears lower both high and low range ratios.
Check the figures with manufacturers, but some lower high range by 22% for eg
So yes this can help with 2wd
jtraf
Re: zook gearing
Post by jtraf »
Series 3 & 4 rockhoppers fix both offroad and road gearing...........
tomzook
Re: zook gearing
Post by tomzook »
OK solved. Thanks for the help. So which TC gears are known to be the best???
Re: zook gearing
tomzook wrote:OK solved. Thanks for the help. So which TC gears are known to be the best???
Anything except "rockhopper" brand. Just my opinion.
Calmini have a good rep.
Marks 4wd adaptors also.
I've not had personal experience, just hearsay.
Re: zook gearing
Trail Tough.
