Onboard air - new solution
http://www.lowrangeoffroad.com/index.ph ... mta24.html
Whilst I'm a huge fan of Endless air/York underbonnet setups, this is really the business - 56amp peak load, over 6cfm flow.
The smaller endless air setup, as used by Greg, has about the same air delivery. I think that makes the ARB setup a winner - you can mount it anywhere, it contains the pressure switch etc ready to run into a tank, and there's no troubleshooting belt setups etc.
Obviously it requires a good alternator, but with falcon upgrades being so easy and cheap, it's a no brainer.
As an interesting aside, it seems ARB reckon you can run lockers at 150psi - the pressure switch on this compressor runs out to 150psi, not 100psi like the other airlocker compressors.
Re: Onboard air - new solution
It is added to wish list,
along with everything else :)
I propose a bulk buy!
I will take 4 - one for each tyre :mrgreen:
