Suzki Rims and Offsets
For future reference the following are stock rim sizes and offsets taken from the Tyre Industry Bible plus a few aftermarket steel rims. Feel free to add any others.
Centre Bore 108mm
PCD 139.7mm or 5.5" except Grand Vitara '05 onwards 114.3mm or 4.5"
Wheel Stud (5x) M12 -1.25 ('98 & earlier) M12-1.5 ('98 & on) Please confirm.
Model Rim Size Offset
Sierra 15' x 5.5" 10P
Vitara 15" x 5.5" 25P
Vitara 2.0 V6 & 4cyl 16" x 6.5" 25P (steel & alloy)
Grand Vitara/XL-7 16" x 7" 5P
Jimny 15" x 5.5" 5P
Grand Vitara '05 on 16" x 6.5" (45P)
Grand Vitara '05 on 17" x 7" (45P)
Speedy Desert Rat 15" x 6" -3
Speedy Desert Rat 15" x 7" -15
Speedy Desert Rat 15" x 8" -28
Speedy Desert Rat 16" x 7" 0
ROH Trak II 15" x 7" 3P
ROH Trak II 15" x 8" -10
King 15" x 7" -13
King 15" x 8" -23
King 16" x 7" -13
Dynamic 15" x 7" 5P (approx.)
Dynamic 15" x 8" -9 (approx.) & -25 (approx.)
This site has a quick backspace/wheel offset conversion chart and also tells how to measure and do the calculations.
http://www.wheelandtiredesigns.com/tech.php
Re: Suzki Rims and Offsets
Resist the urge to machine material off calipers if they touch other components ( usually rims, but hubs on 4WD's can also be in the way ), the pressures and forces exerted within the caliper structure are very significant - especially in the bridge area.
Have heard of a stock cast caliper broken by hydraulic pressure ( some #$%^, incorrectly reconnected an ABS unit - had to rebend the lines to do it as well.... ). That's how much pressure an ABS pump can create. Tried to return it as a part defect !
Don't think an engineer would be too impressed either if that's the way your heading, but for your own and the safety of others - GET YOUR BRAKING SYSTEM RIGHT !
Lloyd ;)
zookstir
Post by zookstir »
I have ROH Trak 2 15" x 6" rims which are 0 offset (welded true centre).
