Most bearing suppliers don't stock the hub nuts. Suzi world said they can get them...is there anywhere closer to South East melbourne that might have them?
I had a little incident which has destroyed my front wheel hub and wheel spindle AND free wheeling hub.
While i'm in there i'm replacing swivel hub seals, kin pin bearings oil and hub seals etc which come in a SH20 kit from Bearing Wholesalers.
So i need hub nuts, washers, lock washers and a free wheeling hub. i already have replacement wheel hub and spindle.
Any ideas?
best place to buy hub nut, washers, lock washers etc...
Re: best place to buy hub nut, washers, lock washers etc...
last bearing kit I got from there had new hub nuts/locking ring in it.
I probably got some kicking around here, but not as good as new.
I will look into my pile if you want.
The only place I know for stuff the regular bolt and bearing shops don't carry is Keables in the CBD.
It can be expensive if you don't have an account as they have a minimum charge of $27.50 (if nuts and washers cost $10, they still charge you $27.50).
http://www.keable.com.au/
Thanks guys, I've scrounged up some second hand stuff which will do the job....got new bearings but no hubs nuts came with them...
