AT2013 - 9-11 March 2013 - X-Treme!
Re: AT2013 - 9-11 March 2013 - X-Treme!
Greg wrote:
dank wrote:I'm in....
Cheap chinese turbo upgrade before the tour? You reckon my ecu can put enough fuel into it?
Edit: hmm....
http://www.jaycar.com.au/productView.asp?ID=KC5385 + associated bits...
Last time I was on a trip with you I recall that you couldnt even get fuel out of the fuel tank Dank.
I reckon ecu fueling might be the least of your worries ;)
Nah i think it was the other problem Greg it kept coming out! Got that sorted now. NEW battery terminals as well. Just about to put another battery in as well.
porter.8.luke
Post by porter.8.luke »
So team what is the direction of the trip? East agen?
Luke
Joshyboy26
Post by Joshyboy26 »
id be keen for a shotgun.
I wont have a front locker by then unless I weld one as I dont want to spend any money on the front till I get chromos
Joshyboy26 wrote:id be keen for a shotgun.
Com'on josh! It's still months away.
What have you got in the back diff now? is it a locker or a spool?
If it's a locker - move it to the front, get the chromos in and put a welded diff or spool in the back. Problem solved!
Double toughs are down to $290 from $480 at the moment, I should be ordering some in the not too distant future if you wanted to split shipping!
sierrajim
Post by sierrajim »
Edit: hmm....
Don't you also have a habit of forgetting to put fuel in as well?
lbzook wrote:Double toughs are down to $290 from $480 at the moment, I should be ordering some in the not too distant future if you wanted to split shipping!
will it bring the cost down though ? if it is based on weight.
are you getting them from lowrange?
mika
Post by mika »
add me to maybe's please
They're from trail tough, i assume it would be cheaper, but I've only been quoted one set at this point. If anyone else is looking at getting some ill email them about getting a quote on more than one set
Be careful, multiple orders can attract import duties etc, if dollar value goes too high.
Discuss with TT before buying, as they may be able to post separately.
Otherwise single orders can be cheaper.
