Starving issue maybe M13A
greyghost
Re: Starving issue maybe M13A
Post by greyghost »
the next sensor that can give issues is the crank angle sensor
rob one off someone and test that if the issue reappears
Thanks Mitch,will give it a go.
Have changed the coil packs for some from pick a part
Issue still remains.
Would the crank angle sensor be the same on the Holden Cruze as there is one at pick a part I could rob
greyghost
Post by greyghost »
I can't see there being much difference, but I don't know
they are after all just a "hall-effect" switch
