Hi,
Would anyone have a jig or drawing dimensions on welding new spring perches on WT diff Housing to suit NT chassis?
Could we chat about RUF conversations at the next shed tech session please?
Diff conversation
Re: Diff conversation
I have a jig but it only works for the rear and only when bolted in to my jig as a full floater, sorry.
Normal procedure is to remove one at a time and keep the angle the same as they’re moved in*. Unfortunately they sort of overlap so you can’t really use one to reference the other. Measure 45 times weld once.
* unless you want to add caster at the front, which I’d recommend.
I finished a wt to nt spacing conversion not long ago. I'm a real noob. Steve provided a lot of good advice. Feel free to PM me with any questions you might have. I did build a jig of sorts for the front but my work is unproven at this stage so keep that in mind.
G’day B sorry for late reply, well done!
I’ll PM you ASAP
I’ll PM you ASAP
